what size blocks?
Old Jan 3, 2012 | 08:46 PM
Buck Slayer's Avatar
Buck Slayer
Default what size blocks?
I've got a 2" leveling kit and my truck sits perfectly level but has lost its rake and looks like its almost leaning back. What size rear blocks should I go with? Also could I maybe go with a 3"aftermarket spacer?
Old Jan 3, 2012 | 08:58 PM
SilverSS's Avatar
SilverSS
Have you thought about getting an add a leaf? Most likely the rear has lost some height because of the springs sagging. I got a pair for around $45.
Old Jan 3, 2012 | 11:58 PM
Buck Slayer
Well I had thought about some hellwig helpers because those actually increase load capacity but don't raise the truck that much.
Old Jan 4, 2012 | 09:01 AM
SilverSS's Avatar
SilverSS
The aal's said they raised The rear 2 inches and increased load carrying capacity by 600 lbs. I didn't measure how much it lifted the rear of mine but it was bulldog and now it has a slight rake. Didn't change the ride much either. I'll get a link to them when I can get on a computer.
Old Jan 4, 2012 | 06:18 PM
BackwoodsRam's Avatar
BackwoodsRam
get the shackle flip kit from topguncustomz. it around 400 shipped. it will allow ou to remove your rear block entirely and give you about an inch extra lift in the rear of a stock suspension. it also requires no welding. you just cut out you old rivits that hold in your shackle hangers
Old Jan 4, 2012 | 06:50 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
$400!?!?
BDS kit is $200 ish (~4.5" lift)
RuffStuff Specialties has a universal that's like $180 ish
Old Jan 4, 2012 | 06:56 PM
BackwoodsRam
yea but you wont have yo worry about axle wrap or a block popping out. and it drops the from mount aswell. so the axle stays centered in the wheel well.
Old Jan 5, 2012 | 12:07 AM
SilverSS's Avatar
SilverSS
Here are the aal's- on sale for $35 no less lol. Maybe you could give these a try and if it doesn't raise it enough then put a taller block on.
http://www.autopartswarehouse.com/se...+a+leaf&submit=
Old Jan 5, 2012 | 01:09 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Now THAT is reasonable pricing!! Good find.
Old Jan 5, 2012 | 10:42 AM
Buck Slayer
Wont I need new u bolts with the aal's?
