Glow Shift Gauges
#32
It's from Glowshift.
They're in, but not finished. Engine oil temp is complete. Trans temp and vacuum are next. No vacuum lines on the drivers side of the V10. I'll need to add on to the line and find something on the passenger side to splice into.
The electrical was easy. Found taps for everything on the fuse panel and used those 'add a circuit' pigtails.
![](http://img839.imageshack.us/img839/3128/img3844z.th.jpg)
#33
Unless you are putting it the pan, get one of these if I have not already suggested. You will not be sorry. It's the most accurate place.
http://dieselmanor.com/dm_products/FTG-MFD.asp
As far as the vac goes line goes just use a "t" (I think the vac gauge comes with one), make sure you put it between the intake manifold and before a check valve.
![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
#34
Yep, that's what I'm using. I bought it after you recommended it in another thread.
The only vacuum line on the drivers side is the brake booster and the line is much bigger than the T in the kit. The air box covers the top of the engine back to the cowl and I couldn't find vacuum there. There's a couple hard vacuum lines on the passenger side I might use. I'm also trying to find where the hvac system gets vacuum from the engine and splice into that, but again, the air box and intake on the V10 hide nearly everything.
#35
