my truck do this when towing?
Old Feb 9, 2012 | 11:36 PM
cutthroatxxx's Avatar
cutthroatxxx
Originally Posted by Ramcountryboy
Depending how many miles are on your truck, it would be wise to do the timing chain especially while it is tore apart. I did mine at 160000ish miles and there was ALOT of play in it. If there is alot of play like mine had, timing wont be exact and you will lose power. Worst case scenario, it can start to skip or break ect. and then stuff is really FUBAR. I'm thinkin they around $40ish? Been a while, correct me if I'm wrong...
Got ya,Im wondering if I should just hold off till the baby comes&pull it down in the garage&do it all myself then just not sure if I can squeeze the time to do it.Ive read the sticky&read the diy in my haynes.It dosnt seem too hard.
Old Feb 10, 2012 | 12:00 AM
gdstock's Avatar
gdstock
Originally Posted by cutthroatxxx
Why replace the timing chain?I got a kid due like yesterday&a 1 year old so I have zero time to fix it.So even though I dont wanna Im probably just gonna take it to a shop for now&wanna keep my cost down.
A good double roller timing set is around $50. At 134,000 miles, mine had about 3/4" slack in it. It is a good investment while you have the intake off. Not required, but it won't ever be any easier.
Old Feb 10, 2012 | 12:14 AM
cutthroatxxx
If I do it myself Ill probably go ahead&replace it If I have the shop do it Ill hold if.it has around 129xxx
Old Feb 11, 2012 | 06:39 PM
redneck_ram's Avatar
redneck_ram
i just towed a tandem axle car trailer on tuesday. about 30 miles 2k pounds unloaded to the destination, and then 30 miles home 6k+ pounds loaded down with a 98 grand cherokee.
5.2 just shy of 180k, and i took it easy, did pretty good on the on ramps, although speeding up was a PITA it wasnt completely gutless. i do have a new timing chain, hughes plenum fix, and a superchips 93 tune. so im sure it helped a little.
3.55 gears and 285/75/16 tires.
