what to look for?help me please
Old Feb 15, 2012 | 08:01 PM
ChargenU's Avatar
ChargenU
Default what to look for?help me please
whats going on everyone im in the market for a older dodge ram.. not looking to spend more then 3500 to be honest,ive been looking on craiglist an found a few nice looking one but miles are all over 130,000 an i want to know WHAT should i look for when i go to look? an HOW do i know if its going to last on me?
whats normal milage the v8s last up to? please help me
Old Feb 15, 2012 | 09:02 PM
ChargenU's Avatar
ChargenU
54 views an no help? come on guys
Old Feb 15, 2012 | 09:54 PM
jasonw's Avatar
jasonw
Site Moderator
Well, it would help if you put it in the right category. I'll move it for you.
Old Feb 15, 2012 | 10:05 PM
Nereaga's Avatar
Nereaga
$3,500 for 130,000K is about right, I just got a new gen 2 and mine had 98,000K for $5,000.
Look for ANY visible leaks, weather it would be from radiator, oil pan, transmission/trans pan, look at Power steering pump and lines for leaks, check the valve covers for oil leaks, inspect the exhaust system, and inspect the differential pumpkins for leaks.
Most likely you will see some sort of rust, look under the truck on the inside, on the metal for signs of major rust, typical spots are along the bottom of the truck, rust on the doors, and wheel wells.
Make sure the transmission is shifting properly. Make sure you take the truck to a parking lot and do some figure 8's and check the steering for pops, noises, and grinding.
If it is a 4x4, check the four wheel drive system, making sure it engages all the gears, make sure you try it out on a stone parking lot, do NOT use the 4x4 on a dry road.
hmmm that's about all I can think of now.
Brad
Old Feb 15, 2012 | 10:10 PM
gdstock's Avatar
gdstock
Check tranny fluid in Neutral. See if it is a light red color and not burned.
Remove air cleaner and look insude throttle body with mirror and flashlight. You are looking for oil pooled inside on the bottom of the intake. If it is there, the plenum gasket is blown.
Bang on cat and see if it rattles.
Old Feb 15, 2012 | 10:13 PM
safrantz's Avatar
safrantz
I say get a 2nd gen for less than 1000 and then fix what you like
*disclaimer...I'm doing this and it has yet to work out!*
Old Feb 16, 2012 | 12:43 AM
ChargenU's Avatar
ChargenU
Brad
im just scared of getting it an the motor blows in little while or tranny
how good to the motors last up to? with towing an stuff
Old Feb 16, 2012 | 07:07 AM
Nereaga's Avatar
Nereaga
While I was looking for my truck, I came across a ton of trucks with higher mileage, like 200K+, still running.
The transmissions usually get beat up pretty good from the 5.2/5.9 engines, big engines with torque. Good thing is they are not too hard to find at a junkyard or to rebuild one. Engines can be a bit more expensive to rebuild.
Truth of the matter is your taking a chance with ANY used vehicle you buy. You can do all your research and think you are getting a deal and then bam, tranny goes or head gasket. I believe a member on here had his tranny go after 4 days after he got it... Crappy luck!
Brad
Old Feb 16, 2012 | 09:51 AM
lastrights's Avatar
lastrights
These motors will last the time of the truck , tranny will go 4 times before the motor
Old Feb 16, 2012 | 05:10 PM
Nereaga's Avatar
Nereaga
Take your time while checking out a truck, check ALL functions of the truck. Test the E brake! I just went to use mine for the first time and it is in need of severe adjusting...
Something I forgot to check... Take a good ride in any vehicle, good 20-30 minutes til everything is warmed up and running like it should.
Hope that helps!
Now go find a bad *** rig!!!
