tell me if it's worth it
Old Apr 4, 2012 | 04:20 PM
mj23polaris's Avatar
mj23polaris
yea it looks like a set of chevy dually axles (look at teh hubs), find a ford dana 60 n make coil buckets or run coilovers, 78-79 ford 60s are king pin high pinion, 86-91.5 are king pin high pinion, and 91.5- 98 ball joint high pinnion,
Old Apr 4, 2012 | 05:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Buy a 2500 for $2900.
Old Apr 5, 2012 | 01:50 PM
dipsherry's Avatar
dipsherry
i actually found a 2500 ram for $2600 hell i will buy it pull axels and part out the rest
Old Apr 5, 2012 | 02:12 PM
dipsherry's Avatar
dipsherry
In the pix below you can see the cast in leaf spring mount, flat side should be up, making this a pass side pumpkin. It is a Kingpin front that's for sure.
your correct fine sir so no worky for me i am just continuing to creep c-list till i find something....would be nice to find a set of dodge axles and make life easy but with me nothing is ever easy
Old Apr 5, 2012 | 04:46 PM
mj23polaris
id swap t cases to
and if ur ambitious enough to pull the OD housing off the trans id prob buy it off ya, i need a new one mines got a big stress crack in it
