advice for possible purchase
Old Apr 22, 2012 | 03:24 PM
  #31
Wombat Ranger's Avatar
Wombat Ranger
That's what you get for buying a truck without seeing it or driving it first...
Did you get these alleged statements about it basically being a brand new truck in writing?
Old Apr 22, 2012 | 03:43 PM
  #32
DylanV318's Avatar
DylanV318
if i get the 2500 would it get the same mpg that you guys were saying the 1500 would? and if i get the 2500 with the cummins would that have the 4.10 gears in the rear end?
Old Apr 22, 2012 | 03:57 PM
  #33
Wombat Ranger
Well, if it had 4.10's in it then it would have 4.10's in it... Some came that way from the factory, but many have 3.55's. Cummins will get significantly better fuel economy, but maintenance/repair costs will have you running and screaming...
Old Apr 22, 2012 | 04:31 PM
  #34
gdstock's Avatar
gdstock
And diesel costs more per gallon....
To check the gears in diff, there is a metal tag (or should have) on the differential. Actuall, there should be 2 tags. One will show the gears. Also, a build sheet from Dodge will show what came in the truck from the factory.
Old Apr 22, 2012 | 04:48 PM
  #35
zman17's Avatar
zman17
Retired Moderator - RIP
+1, Anyway, all you have to do is look at the sticker on the radiator support, or open the glove box and look at that sticker to find out what gears it has.
Old Apr 22, 2012 | 07:19 PM
  #36
DylanV318's Avatar
DylanV318
did the 2500s come with the 318 or are all the gas engines 360s? plus from looking on crags list the 2500s are seeming to be more expensive than 1500s
Old Apr 22, 2012 | 07:31 PM
  #37
Wombat Ranger
Um yea, 2500's are more truck, so they cost more. The only 2500's that ever came with a 5.2 were the 94-95 light duty models, which were essentially a 1500 with 8-lug hubs and 2500 brakes. You will most likely not come across one of those, but if you do, it's not worth anything more than a 1500 in my opinion.
