Leaking Master Cylinder Reservoir Cap
Old May 19, 2012 | 09:35 PM
Matt Nickerson's Avatar
Matt Nickerson
Default Leaking Master Cylinder Reservoir Cap
Quick question... My brake master cylinder reservoir cap is leaking out a little bit of fluid every time I drive the truck-I'm pretty sure it just recently started a couple days ago. Is it a simple fix of just replacing the cap or is there a different issue going on? The gosh darn cap is $15.00 at the dealer which is a far away drive as it is, and I was just there like two weeks ago so I wanna make sure that's all it is.
Anyways, previous work to the brake system was just pads, rotors, and a hub assembly a few months ago. Nothing else was touched and I haven't put any extra fluid into the reservoir so I'm fairly certain it isn't overfilled.
Thanks for any help.
Old May 19, 2012 | 09:38 PM
Where do you think all that fluid goes when you compress the caliper pistons?
There should be a little 'level indicator' type window on the side of the tank, check and see if it is indeed at the correct level. My guess is, it's a tad over full.
Old May 20, 2012 | 01:55 AM
johnnyjaws98's Avatar
johnnyjaws98
get a used one
Old May 20, 2012 | 01:58 AM
gdstock's Avatar
gdstock
+1 on this. Also, check your local auto parts store in the HELP section (dorman products) and see if they have one that will fit.
