Tire cherp
Old May 24, 2012 | 01:04 PM
Ram3602500's Avatar
Ram3602500
Default Tire cherp
When I take a corner (and it doesnt have to be a big one) and theres a bump or something my tires cherp and they do it sometimes if I hit a bump going straight as well any ideas?
Old May 24, 2012 | 01:17 PM
crazzywolfie's Avatar
crazzywolfie
how is the tire pressure? mine start chirping going around corners when they hit about 25psi.
Old May 24, 2012 | 02:39 PM
Wombat Ranger's Avatar
Wombat Ranger
Pop your rear end open, see if you have a locker, or if your spider gears are welded.
Old May 24, 2012 | 04:22 PM
Ram3602500's Avatar
Ram3602500
What if they are welded or I have a locker? Is there something I can do?
Old May 24, 2012 | 04:24 PM
Wombat Ranger
If you like to off road you can enjoy the extra traction, and live with the side effects, or if you don't, you can swap in an open differential carrier. This requires setting up the ring & pinion again.
Old May 24, 2012 | 08:05 PM
Ram3602500's Avatar
Ram3602500
Default thanks
no Im a off roader I will live with the side affects
Old May 24, 2012 | 08:06 PM
Ram3602500's Avatar
Ram3602500
Default thanks
ok makes sense Im a off roader I will live with the side affects
Old May 24, 2012 | 08:38 PM
Wombat Ranger
I would still check to make sure it's that, and not something else.
Old May 24, 2012 | 09:11 PM
gdstock's Avatar
gdstock
THIS is true. Better to know for sure than guess and be wrong.
