knocking sound in oil pan
Old Jun 22, 2012 | 02:54 PM
aj shivers's Avatar
aj shivers
Default knocking sound in oil pan
hey everyone i am a new member and i need some well needed advice i bought a 98 dodge ram 1500 4x4 and since i got it ive had nothing but problems i replaced the oil pan gasket this morning and after i put it back on there was a slight knocking noise coming from inside the oil pan and i have no idea what could be causing this i didnt replace anything else any info would be greatfull
Old Jun 22, 2012 | 06:27 PM
stewie01's Avatar
stewie01
You could get crazy and drop the pan, see what you find....
Old Jun 22, 2012 | 06:49 PM
QuadCabLuv's Avatar
QuadCabLuv
^^^^ lol if you do drop the pan check for your magnet that should be in the pan. Might have knocked it loose. Also inspect for a broken crankshaft. I had a ram that made a clunking and suspected rod knock buy i was hearing it from the pan, ended up being a broken crank.
Old Jun 23, 2012 | 12:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you replace the pan too, or just the gasket?
There is no magnet in the oil pan.
Old Jun 23, 2012 | 01:59 PM
QuadCabLuv's Avatar
QuadCabLuv
Funny my 1500 had one....
Old Jun 24, 2012 | 02:08 PM
Ham Bone's Avatar
Ham Bone
Check you're inspection plate. Mine got loose when I changed my oil pump and rattled something crazy. I thought my truck was about to blow up.
Old Jun 25, 2012 | 10:19 AM
aj shivers's Avatar
aj shivers
where is the inspection plate at? is it the plate that covers the flywheel?
Old Jun 25, 2012 | 10:27 AM
yep, that would be the one.
Old Jun 25, 2012 | 08:28 PM
dhvaughan's Avatar
dhvaughan
when i removed/reinstalled my oil pan and inspection plate cover, my flex plate (flywheel thingy) was hitting the plate and making a horrible noise.
the plate and oil pan have to hook together on that big lip.
if it wasn't banging before, and you removed nothing critical, then you have something hitting.
Old Sep 6, 2025 | 03:37 PM
Brant1's Avatar
Brant1
My hell! Thanks guys! I went through the same headache with my 02 RAM 5.9L 1500. 13 years later!
