Miles per gallon - What are you getting?
Old 10-14-2012, 10:37 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
Originally Posted by Halojm
I'm getting 13 mpg average. The question I have is, how does gears and bigger tires affect the speedometer and odometer. I have 33" tires with 3:92 gears. Doing the equations my effective gear ratio is 3:56 which is factory specs + or - so in theory my speedometer and odometer should be correct as it shows. Am I true in this statement.
in older models with speedo gear in transmission - gear change affects speedo. (along with tire size).
in later models with speed sensor in rear diff that reads the tone ring, the gear change has no effect, and only the tires affect the speedo.
to know for sure, do a speedo test along the highway. hold 60 mph exactly and measure time between the mile markers. 60 mph will travel 1 mile in exactly 60 seconds.
  #122
Old 10-15-2012, 05:56 PM
Halojm's Avatar
Halojm
Halojm is offline
Thanks, I know I have the speed sensor in the rear diff, I remember putting it on the new carrier during gear and carrier swap. I will have to do the highway test then. Does it also affect odometer accuracy. Guess I could do highway test for that too.
  #123
Old 10-17-2012, 12:48 PM
Mutt Bryant's Avatar
Mutt Bryant
Mutt Bryant is offline
LAst time I measured it was 14 but now a year later i think its more like 10-12
  #124
Old 01-24-2014, 01:27 AM
Brucesterj's Avatar
Brucesterj
Brucesterj is offline
Wow.. I get about 20 in town and have seen 26 on the interstate.
Diesels Rule..! just sayin..
  #125
Old 01-24-2014, 02:26 AM
tincan57's Avatar
tincan57
tincan57 is offline
Cummins 18 interstate (empty), 15 town.
Gassers local farm stuff and off road 11.
Diesels do rule for towing and mileage, but there's just some itches they can't scratch.
  #126
Old 01-24-2014, 10:13 AM
BBartow's Avatar
BBartow
BBartow is offline
13-15 MPG Mixed, 16 if I granny it. This is based off the GPS, not the odometer.
  #127
Old 01-24-2014, 11:51 AM
Jigabop's Avatar
Jigabop
Jigabop is offline
15.65 average on the last fill up.
that's with 35" tires, 4.10 gears, and driving at a 380-400rwhp level...
  #128
Old 01-24-2014, 07:33 PM
Brucesterj's Avatar
Brucesterj
You are correct.. Diesel still costs more per gallon. Also a good running V8 with the right muffler beats a Diesel hands down.
  #129
Old 01-25-2014, 04:19 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
8.7 average, but i get ~13 on long highway trips.
I had the pcm updated with tire size when I went to 35's so it's pretty accurate.
  #130
Old 01-25-2014, 04:23 PM
stewie01's Avatar
stewie01
stewie01 is offline
Usually average 15MPG on the trip from Independence to Fairfax, and usually get 15.3MPG from Fairfax to Independence....
Quick Reply: Miles per gallon - What are you getting?
