What I did labor day weekend...
Old Sep 5, 2012 | 11:31 PM
Karride's Avatar
Karride
Default What I did labor day weekend...
I took the long weekend and replaced my plenum pan on my new (to me) truck, along with all the other suggested replacements (Timing set, water pump, hoses, Thermostat, and ignition), and also converted to a Electric fan.
I have never replaced a timing set before and was somewhat nervous about messing it up, but thanks to all the info here I did it and had no trouble. I got everything done in about 24 hours worth of work. To anyone who is
nervous about doing this the plenum pan, I would say if you are reasonably mechanically inclined, you can do this.
Truck is running smooth now, and seems to have a lot more pep than it did before. Used to I had to really push the gas to get going, now just a little pedal does the trick
I meant to take a lot more pictures, but got engrossed in the work and forgot.
Here is my engine at the start
All the accessories removed. the upper hose was frozen in place, so I just cut it since I was replacing it anyway.
I think I had a leak, what do ya'll think?
Old timing set, lots of play.
Everything reinstalled up to the water pump (I know, I suck at taking pictures).
Prepped plenum from junkyard donor installed
On to the Electric fan, I got a Mark VIII, shaved off its mounting ears and mounted it into the stock fan cowling. Almost a perfect fit!
Fan controller and fuse mounted on Passenger side firewall (Wire will be wrapped in split loom later...stuff I bought was not big enough.
Hard to see in this picture, but the fan clears the water pump by about 1/4"....If I had to do it over, I would set the fan in by about an inch for more clearance.
Engine bay now. Still need to buy some split loom for those fan wires.
Bottom of pulled plenum....Yummy!
The plenum pan gasket seemed to be intact, but there was a fair amount of oil sitting in the pan,, and it was all under the gasket.
Bad PCV Valve maybe causing the oil issues? I'm going to replace just to be safe.
Some things I learned:
Labelingeverything really, really helps.
If renting tools, test them thoroughly before leaving the store. I spent an extra 45 minutes putting the balancer back on because my installer tool needed some encouragement.
In my opinion, an extra pair of hands is essential. at a minimum, you need someone to jam the flywheel so you can torque the balancer back on.
Once you get the fan, shroud, and accessory bracket out, climb down in the engine bay to work as others have suggested; Your feet will curse you, but your back will thank you
Much as it sucks, I agree with replacing all the stuff people say you should replace when doing this.
in addition to all the other things people say you should replace when doing this, I would add replace the valve cover gaskets. At a minimum, check that the bolts are properly torqued...most of mine were finger loose!)
Old Sep 5, 2012 | 11:39 PM
UnregisteredUser's Avatar
UnregisteredUser
Yep, that's a failed PCV valve.
Our valve cover gasket bolts are notorious for backing out like that, and in no more than the span between oil changes. If I ever get up off of my lazy backside and do it I might have a workable fix, but I'm not going to make noise about it until I know it's a fix and not just busy work.
Good on ya for taking that job on and doing it up right!
Old Sep 6, 2012 | 12:21 AM
gdstock's Avatar
gdstock
Looks good!
Old Sep 6, 2012 | 07:04 AM
dhvaughan's Avatar
dhvaughan
nice work. congrats.
Old Sep 6, 2012 | 08:45 AM
Uggh...I know I can do this, and I know it needs to be done, and it's basically unbolting stuff and bolting it back on....but...ughh...
Old Sep 6, 2012 | 09:21 AM
Karride's Avatar
Karride
I understand not wanting to. Now that I've done it, I could probably do it in half the time...not eager to try anytime soon though
Old Sep 6, 2012 | 11:09 AM
Karride's Avatar
Karride
Maybe if nothing else some threadlocker on the studs? Funny thing to me was it was only the outer studs that were loose, inners were still fine.
Old Sep 6, 2012 | 03:31 PM
UnregisteredUser
That'd probably do the trick. I'm going to throw hardware at it.
The outers are on the hotter side of the head, so see more thermal expansion.
Old Sep 6, 2012 | 03:50 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Good work OP. Take better pics next time. jk
termah espanshun, whatevah
Old Sep 7, 2012 | 04:27 PM
LegendKiller89's Avatar
LegendKiller89
well done, good job man.
