How to remove 46RE gov pressure selenoid
I have 1999 1500 5.2 2WD and the tranny has lots of metal flakes in it after I changed the fluid 4K miles ago. Also I cut the filter open and it looks like pieces of fiber clutches in it ( 5-6 small). I want to clean it and replace filter and fluid so I can drive it to tranny shop to get the bad news. Any help is much appreciated. Eric oh the tranny is 46RE.
Not much to tell you that you do not already know. With the pices of debris you mentioned, a rebuild is necessary. Depending on where you are, it may be expensive. Most often it seems that the cost is around $1200.
Gov pressure solenoid removal requires pillung the block it is mounted in (4 bolts I think) and removing the M clip inside the block.
