I need more specific tow ratings. 4x2 5.2 manual 3.21 axle
Old Oct 5, 2012 | 05:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There should also be a sticker in the glove box.
Old Oct 5, 2012 | 10:42 PM
Nick Bain's Avatar
Nick Bain
Originally Posted by SilverSS
Most of the Dodge's you'll find will have the 3.55 gears. Kind of ironic you found one with a 3.21 as they weren't very common. The next step up from the factory is 3.92's and then 4.10's. 3.92's or 4.10's would be the most desirable factory gear for towing, then the 3.55's. There's a sticker under the hood that will tell you what gear is in the truck; also a tag on the rear itself. Happy hunting
yeah no, my dad had a 99 van hd with 3.92 gears, lsd. That thing was sweet. until the unibody **** frame rusted out in the front. Only towed a 15 foot 65 horse boat with it but it was like the boat was not even there.
Also here is the link to that truck and yes It is a 3.21 according to the sticker under the hood. It would be a sweet truck to have if you never had to tow anything. First gear was the perfect size to leave it in for a near stop and it spun 1500 rpm at 60
http://minneapolis.craigslist.org/hn...286611598.html
Old Oct 6, 2012 | 09:27 AM
dhvaughan's Avatar
dhvaughan
i think? the 3.21 rear gear might have been standard for a manual transmission.
Old Oct 7, 2012 | 02:01 PM
cruzer55's Avatar
cruzer55
Also trailer sway control and equalizing hitch are required for tongue weights above 350 lbs.Max tongue weight on 1500 is 700 lbs.Hitches with a class 1,gross trailer weight is 2000 lbs,class III gross (GTW) 5000 lbs.Class IV hitch 13,600 lbs depending on your vehicle equipment.5.2 with auto, all axle GCWR is 12000 lbs.Max trailer weight 6.5 bed is 7,700 lb.8 ft box is 8000 lbs.hope this trivia helps.Deduct 2000lb for manual trans.
Old Oct 7, 2012 | 11:14 PM
Hahns5.2's Avatar
Hahns5.2
IMO, deducting weight for manual trannys is BS. They're stronger, the dealers just didn't want to put up with idiots who don't know how to use a clutch. FWIW, in the Dakotas, the manuals did have a higher rating than the autos.
IMO, 1st is low enough that it shouldn't be a problem and with the taller gears, towing in 4th gear should be at a more comfortable RPM.
Old Oct 11, 2012 | 12:16 AM
Nick Bain's Avatar
Nick Bain
Yes based on what i've seen he is backwards on the manual trans deduction. Based on the research qouted in my original post.
Axle ratio is showing to be the dominant factor.
the feel for the driver and rpm is good in low gears but with a tall axle ratio it is bad on the drivetrain, hence the dramatically lower tow numbers when the axle ratio drops and towing not recomended with the 3.21.
Old Oct 11, 2012 | 06:36 AM
cruzer55's Avatar
cruzer55
All info that was posted,straight out of the OWNERS Manual,check it out>>>>just a thought.cruzer
Old Oct 11, 2012 | 03:13 PM
Z.rawk95's Avatar
Z.rawk95
My truck came with 3.21s from the factory, its an auto, they suck, but we havnt have any problems any of the times weve had to tow, which isnt often, but still no problems. Really want to go up to 3.92s at some point, but thats not gonna be any time soon.
