Dodge Forum Veteran Here - Need Advice
Old Oct 11, 2012 | 08:39 PM
  #41
Wombat Ranger's Avatar
Wombat Ranger
What color is the truck in question?
Old Oct 11, 2012 | 10:35 PM
  #42
The Browns will win a game. Eventually.
Old Oct 12, 2012 | 09:43 AM
  #43
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by VWandDodge
Also remember that a 55-gallon drum and a shovel can solve many of life's problems as well.
Originally Posted by zman17
That's the solution for life's bigger problem's.
Originally Posted by stewie01
Time to leave the mobile home park
Old Oct 12, 2012 | 10:21 PM
  #44
Sheriff420's Avatar
Sheriff420
Originally Posted by Ram It Hard
Most things in life can be dealt with a gallon of gas, few matches, and a case of beer.
What, no marshmallows?
Old Oct 12, 2012 | 11:32 PM
  #45
gdstock's Avatar
gdstock
Here's a word of advice, STFU .
Originally Posted by UnregisteredUser
If alcohol is not the answer, you've asked the wrong question.
OR...the question was not phrased correctly.....
Old Oct 12, 2012 | 11:41 PM
  #46
Sheriff420's Avatar
Sheriff420
If you need to work on a phone jack, make sure you disconnect the lines in the box outside first. It's almost guaranteed that a telemarketer or a bill collector will call right when you touch the contacts in the jack. That mess feels like getting hit with a mouse trap.
Old Oct 13, 2012 | 09:03 AM
  #47
dhvaughan's Avatar
dhvaughan
when you are removing bats from a louvered house vent and you are up on a ladder about 20 feet up, here are several tips:
1. do not turn on the floodlights. this attracts bugs which attracts more bats and its unnerving as they as zipping about you.
2. do not put the ladder directly under the louver. when you spray them with windex or 409 or whatever chemical you choose to blast them with, they will sort of fall out of the louver in a disoriented state. its unnerving when they land on your head, chest, and arm and it takes a lot of concentration to not fall off the ladder.
3. after removal of the bats, staple screen wire over or around the outside of the louver to keep them out. this works well.
Old Oct 13, 2012 | 09:49 PM
  #48
Sheriff420's Avatar
Sheriff420
When lighting charcoal, a propane torch works wonders.
A charcoal chimney with some of those fire starter cubes that look like marshmallows works great too but it takes longer than the torch.
A pump for an air mattress works good to speed up the process in the charcoal chimney once the bottom coals are lit.
I don't care to wait for coal to light when I'm ready to cook.
Old Oct 13, 2012 | 11:09 PM
  #49
dhvaughan's Avatar
dhvaughan
a leaf blower will speed up the charcoal burning process. also will speed up a good brush fire.
when starting a brush fire using diesel fuel, and the fuel is old and the brush is wet and its just not burning good - you might be tempted to add a splash of gas to the diesel fuel to warm it up a bit. don't do it...... it works good the first time you do it, but after several months you will forget that you added gas, and you will forget to shake it up. you will then pour out some of what you think is diesel fuel only to discover that its the separated, lighter, more highly volatile gasoline that you pour out on your next brush pile. the results are very uhm, exciting.
do NOT start a charcoal fire with diesel fuel. your hamburgers will taste exactly like diesel fuel.
Old Oct 13, 2012 | 11:16 PM
  #50
dhvaughan's Avatar
dhvaughan
beer can be chilled instantly with a CO2 fire extinguisher or paintball tank, or coke/beer CO2 tank.
