Dip stick hard to push in tube
Old Oct 15, 2012 | 09:40 PM
QuadCabLuv's Avatar
QuadCabLuv
The dipstick tube has one bolt an bracket about halfway down. The tube itself is just pressed into the block. You have to be careful to not snap it off at the block, mine did. Theni spent the subsequent 3 hrs trying to remove it. I suggest soakig it thoroughly for a.couple of days with some pb blaster. I ended up using freeze off, torch, and easy out and still.did not getthe.remainder out, came back the next day an it just popped.out. Lol
Old Oct 15, 2012 | 10:13 PM
dhvaughan's Avatar
dhvaughan
i think mine just sort of fell out. but if not, don't break it. then you've got an assload of problems.
Old Oct 16, 2012 | 01:32 AM
MoparMan1991's Avatar
MoparMan1991
Have you tried turning the dipstick around in a 90 or 180 degree turn? The dipstick I have on my 4.7 does this if I try to push it in and its not in the correct position.
Old Oct 17, 2012 | 10:09 PM
trip94's Avatar
trip94
Default I have the same problem.
I also have a 96 ram 1500 with a 5.9. I just recently bought it and noticed the same problem with the dipstick. Not sure whats holding it up but I bet its a pretty common issue because i was looking to buy another dodge with the same engine a few years ago and it had the same problem. The guy selling it told me that it was always like that.I hope some of the experts have an answer. I'll be watching this thread. Good luck with an answer.
Old Dec 13, 2012 | 03:47 PM
jake4x's Avatar
jake4x
I actually have been having this same problem with my 96 5.2L Grand Cherokee.
Though my problem didn't start until after I had removed the pan to replace the oil pump. A little while later the motor through a bearing so I ripped it down completely and bought a new dip stick tube. The tube I took out was PERFECT. So is the oil pan. I made sure everything was free and clear before reassembly, with a new tube and even a different pan from a long block motor that the stick slide nicely into. Same problem. I've tried 3 different dipsticks, all the same. Some still had the plastic bit on the end of the stick to help it slide.
I read somewhere else that the stick gets wedged into a corner and has a hard time sliding past. Some people suggested twisting the end of the dipstick a little more (with pliers, outside of the vehicle) so that when it slides into the set up a little differently but that didn't help either. In one instance, it made it worse.
What I'm going to look at doing it using plasti-dip to build up the tip of the stick and try it. If I have any success when I do it, I'll share for sure.
Old Dec 13, 2012 | 04:42 PM
diverjer's Avatar
diverjer
I am just living with mine, found a few tricks to make it work easier.
Old Dec 13, 2012 | 04:46 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I just shove mine in harder. Just make sure you're holding onto it with a rag though, otherwise it wants to bend.
Old Dec 13, 2012 | 05:30 PM
This thread is some quite interesting reading...lol
Old Dec 13, 2012 | 05:44 PM
dlyter09's Avatar
dlyter09
I had that feeling near the start of it lol....
Originally Posted by dlyter09
Dont forget measuring from the a-hole doesnt count... And I would suggest using a little bit of lube to help slide er on in there.... Z man what are gt's?? Giant Toys???
Old Dec 13, 2012 | 05:55 PM
diverjer's Avatar
diverjer
I will make it more interesting. I just clean the oil off the stick, wrap my hand around the tube and dip stick so it won't bend and ram it home. I knew I should have never started this thread, that is why I made the video to show I actually had a problem. Still it does leave room for interruption.
