dodge shifts hard
Old Oct 15, 2012 | 08:39 PM
dodge2500v10's Avatar
dodge2500v10
Default dodge shifts hard
I got a 99 v10 and it shifts really hard. it will rev to about 2700 rpm and shift hard each gear. is this a major problem or something simple?
Old Oct 15, 2012 | 08:50 PM
PurplDodge's Avatar
PurplDodge
Define "shift hard"
stewie01's Avatar
stewie01
How's your fluid level? Check with truck in normal operating temperature, in Neutral (set ebrake).
Old Oct 15, 2012 | 08:59 PM
dodge2500v10
what happens it will rev higher then normal and shift and drop to almost 1000 rpm. it doesnt feel right. i will try checking the fluid.
Old Oct 15, 2012 | 09:11 PM
stewie01's Avatar
stewie01
Sometimes low fluid will cause irregular shifts, not saying that's what your problem is, but won't hurt to check.
If fluid looks ok I would then drop the pan, see if anything is in there that shouldn't be, maybe clean or replace the sensors and filter.
Old Oct 15, 2012 | 09:22 PM
dodge2500v10
ill try that i dont have the truck yet im still deciding whether to buy it or not.
Old Oct 15, 2012 | 09:37 PM
stewie01's Avatar
stewie01
Oh. I would probably walk away from this one. Just my opinion... A neglected transmission = rebuild sooner or later.
Old Oct 15, 2012 | 09:57 PM
dodge2500v10
ya but i like the truck alot.
Old Oct 15, 2012 | 10:02 PM
stewie01's Avatar
stewie01
Well, give it a thorough look over, unless you pretty much know you're buying this truck I wouldn't drop the pan, I'd hate to waste $60-$70+ to refill a transmission for someone else...
Old Oct 15, 2012 | 10:12 PM
dodge2500v10
i might get it for little under a grand.
