Tire wear
Old Dec 6, 2012 | 08:25 AM
Ram3602500's Avatar
Ram3602500
Default Tire wear
My Ram has some steering play and I noticed same tire wear I changed all of the tie rod ends, ball joints and the alingment done, Im gonna change the steering box next but does having some play in the wheel wear the tires?
Old Dec 6, 2012 | 08:37 AM
cruzer55's Avatar
cruzer55
Most tire wear from under/over infaltion,out of alighnment worn parts on the frontend or serious damage too the front end.Full inspection and R&R as needed.
Old Dec 6, 2012 | 11:51 AM
Nereaga's Avatar
Nereaga
These dodges are well known to have steering woes and excessive play/road wander. How are the tires wearing?
Old Dec 7, 2012 | 02:30 AM
Wombat Ranger's Avatar
Wombat Ranger
Do you rotate them regularly?
Old Dec 8, 2012 | 06:22 PM
Ram3602500's Avatar
Ram3602500
They are wearing on the inside of the tires and yes I rotate them regularly
Old Dec 8, 2012 | 06:39 PM
Nereaga's Avatar
Nereaga
Check your steering, mine were wearing like that and I needed a new tie rod end.
Go to an alignment place and ask them to check it out, they will tell you what you need. If you don't need anything, then it will just be an alignment for $60-80.
Old Dec 9, 2012 | 02:20 PM
Jigabop's Avatar
Jigabop
too bad you already did your tie rod ends...would have told ya to get the 08.5+ steering assembly upgrade...truck will drive way better with HD T-steering vs junk Y-steering.
Old Dec 9, 2012 | 02:51 PM
UnregisteredUser's Avatar
UnregisteredUser
Don't tell mine that. The thing tracks like it's on rails. I drove a few 2nd gens when they were new, and they tracked just fine, too. There's no reason to accept crappy steering.
Old Dec 9, 2012 | 07:11 PM
Nereaga's Avatar
Nereaga
I realize that now after having tight steering again. Before with the worn tie rod, steering play was pretty crazy and I thought I might need the rock solid bushing, turns out that tie rod end was bad since I bought the truck... Lol. Rides totally different now, and once my current bald tires are replaced, she will be driving like a Cadillac.
At least that's the hopes anyway
Old Dec 9, 2012 | 07:13 PM
Nereaga's Avatar
Nereaga
Day late and a $1 short... Typical
