Cummins, CAT, International NaviStar, Hemi, Allison, Aisin...
I didn't say that did I? If I did I meant to say rumour has it that Ford will buy Cummins or has... I didn't state it as fact. Ford doesn't own Cummins right now unless it is a messy deal like the Sears-KMart episode...
Interesting. do they make any Hemis other than the 5.7? I'd consider buying one if it was larger than 5.2L but wasn't a 6.0L!
I bet this is just the same thing people were talking about when they had the LAs and Dodge introduced the Magnum. Very similar to the LA, but updated. Probably the same thing with the Hemi?
They make a 6.1L hemi that I believe will be in the 2014 rams
on
hemi 2013– 5.7 L (345 cu in) Hemi V8 395 hp (295 kW) 410 lb·ft (560 N·m)
truck v10 This 488-cubic-inch engine was based on a cast iron block, and was rated for 310 hp (230 kW) @ 4,100 rpm and 450 lb·ft (610 N·m) torque @ 2,400 rpm.
and the big hemi: 2014– 6.4 L (392 cu in) Hemi V8 450 hp (340 kW) 480 lb·ft (650 N·m)
