Dana 60 Swap
Old Jan 10, 2013 | 07:40 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Please double check your D60 tube diameter. The stabilizer link you put up is for 3.75" axle tube.
Here is link to Dodge 2500/3500 3"
http://www.topguncustomz.com/p-943-9...lizer-kit.aspx
Here is the kit I have which is also for 3"
http://www.topguncustomz.com/p-922-9...lizer-kit.aspx
So I'm not sure mine will work for you for obvious size reasons. Check on your end when you're able.
Old Jan 10, 2013 | 08:01 PM
redneck_ram's Avatar
redneck_ram
well, i measured the axle tube the other day, and it was 3.125(measured with a vernier caliper). so thats why i decided to go with the 3.75 stabilzer kit. you think the one you have will work?
Old Jan 10, 2013 | 08:30 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I think you are in luck, just check this over as I have my hp60 sittin here. lol
I have the plate bolted in just not tight
Now only thing is with mounting on the ends to the tie rod. Look at my album here to compare mine. Will your axle Y-linkage? I'm thinking yes b/c of the year. Someone that knows, please speak up.
The album shows pictures of my balljoint, unit bearing, and track bar changeout also
http://s150.photobucket.com/albums/s...20Sept%202011/
Old Jan 10, 2013 | 08:54 PM
redneck_ram
im keeping my factory 01 steering linkage so i should be good to go! pm me a price kind sir!
also.... arw the dodge offroad cam bolts sold in pairs or singley?
Old Jan 10, 2013 | 09:13 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
PM awaiting.
I don't know but on this page, scroll down
http://www.dodgeoffroad.com/store_DORparts.php
Old Jan 10, 2013 | 09:23 PM
redneck_ram
PM awaiting.
i already found them on the website just trying to figure out the quantity per cost.
Old Jan 11, 2013 | 04:27 AM
Dodge Off Road's Avatar
Dodge Off Road
Those prices are per pair. Pretty big savings over the factory bolts!
Old Jan 11, 2013 | 07:37 AM
redneck_ram
thank you! ill be ordering them soon, just need to figure out what size i need.
Old Jan 12, 2013 | 09:46 PM
Dodge Off Road
Sounds good. Let me know if I can help!
Old Jan 14, 2013 | 01:36 PM
redneck_ram
man this is getting harder and harder. i talked to richard over at hipotek and am considering a set of new heads, hughes air gap, custom grind cam from hipotek, and a 52mm tb. glad i dont have much to buy in terms of stuff for the front d60.
of course with all that stuff, ill need a custom tune from hemifever. blah!
