A-pillar gauge pod with speaker pod
Has anyone added a dual or triple pod to the a pillar that has the built in speaker? If so any pictures? I need to add some gauges to my truck but I really like the idea of keeping that speaker
plenty of trucks have...it just gives a mounting hole to relocate the factory speaker..
all of those mounts just stack on top of the old pillar...they do not replace the factory pillar...
mine is a bit more custom, but it does have the speaker mount..
i run this:
with this:
to make this:
i run this:
with this:
to make this:
from the camera angle it looks like it does, but from my view in the drivers seat, the only thing it blocks is the check engine and check gauges lights... though your truck will beep at you when they come on...
beeps at me every time I get to 1/8th tank.
I don't pay attention to the dash speedometer anyway... its off by a few mph... the pulse monitor on my pillar has 1 of its 4 gauge displays showing corrected vehicle speed, and that is what I use as a speedometer.
I monitor EGT, trans temp, water temp, and corrected vehicle speed on the monitor. the two above it are both boost gauges. 0-60psi for the primary stage, 0-100psi for the manifold pressure (post secondary stage)
on the column is my 0-30psi fuel pressure gauge.
