Ordering SCT Tuner, have questions
Old Mar 20, 2013 | 09:12 PM
RageGuy's Avatar
RageGuy
Default Ordering SCT Tuner, have questions
I know there's alot of people on here that have SCT tuners....
Do they come with 87, 91 and 93 octane tunes? or how does it work? I am just getting the bolt on one, because I don't have any mods, except a CAI.
How much of a performance increase can I expect for the $300?
When ordering online it asks me what kind of gears I have, and what my PCM # is, where can I find these? I'm fairly certain I have stock gears.
Thank you!
Old Mar 20, 2013 | 09:14 PM
dlyter09's Avatar
dlyter09
Yes they are worth the money.. with or without mods... Your PCM part number is right on the computer under the hood... Get a build sheet from dodge to check for gears.. Most likely it is the 3.55's... unless they have been changed.. Build sheet will tell you for sure though..
Old Mar 20, 2013 | 09:59 PM
gdstock's Avatar
gdstock
There is also a metal tag on diff with gears indicated. And it does not bolt on, it plugs into OBDII port, uploads, then you disconnect and put it away! Easy! And the canned tunes include the octane ratings you referenced.
Old Mar 20, 2013 | 11:19 PM
beeker's Avatar
beeker
FYI, Hemifever website now calling canned tunes 'bolt-on'
You will not see a big performance boost using the SCT. Whether or not it's worth it is your choice to make.
What you will get:
*It will give you 20 more lbs of torque by removing the torque management. (98 and up trucks)
*Shift points will be changed, truck will downshift out of overdrive to third easier without mashing foot all the way to floor like it normally does.
*Option for custom tuning in the future for more money.
Beware, some have reported damaged PCM from using the SCT tuner.
That's about it.
Old Mar 20, 2013 | 11:34 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Custom tunes will allow you to adjust your stuff when you add more mods later.
Make sure that before you install the tuner than your plenum, cat and 02 sensors are good.
Otherwise you'll be pinging like a biatch.
Old Mar 20, 2013 | 11:48 PM
gdstock's Avatar
gdstock
What you will get:
That's about it.
"Bolt On" as referred to on Hemifever site refers to "bolt on" modifications to engine, such as rockers, headers, etc. As opposed to changing heads and cam, etc.
If not, Sean can correct the next time he logs into DF. But I believe I am correct. The tuner does not bolt on though.
Old Mar 21, 2013 | 03:23 AM
coldsteel5's Avatar
coldsteel5
Damaged pcm???
Old Mar 21, 2013 | 06:20 AM
kejobe's Avatar
kejobe
Originally Posted by coldsteel5
Damaged pcm???
It has been reported here. Few and far between though. I wouldnt (and didnt) let that concern me though. Ive had a SCT tune for over a year now and have changed which tune I run several times. No problems at all.
Old Mar 21, 2013 | 09:13 AM
stewie01's Avatar
stewie01
I haven't gotten to "tune" my truck yet, but I think it's worth it just to get rid of the "death flash".
PLUS the tuner itself acts as a code reader
Old Mar 21, 2013 | 04:10 PM
zach01's Avatar
zach01
i wish it would let you change the tire size like the superchips does
