4.10 gear improve MPG in 98 dodge ram 318
Old Mar 22, 2013 | 06:43 PM
lone_wolf6968's Avatar
lone_wolf6968
Default 4.10 gear improve MPG in 98 dodge ram 318
i have a 98 dodge ram 1500 5.2. am running 33'' on it, with k&n CIA and a flow master exhuast. if i switch my 3.55 gear with 4.10 will it help my gas mileage at all or with it make it worst? i live in the mountains and do must my driving on mountain freeways, lots of up and down. i get 13 mpg right now but am trying to make that a little better.
Old Mar 22, 2013 | 07:14 PM
dlyter09's Avatar
dlyter09
All depends.. I saw city improvement.. Highway it dropped off... Either way it is still a good idea to make the switch.. You will probably stay around 13 or 14 mpg though
Old Mar 22, 2013 | 11:52 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
in the hills you will notice a slight increase because it wont kick out of o/d as often on the up hills
Old Mar 23, 2013 | 12:41 AM
gdstock's Avatar
gdstock
The drive shaft will have to turn more times to make one revolution of the tire. No way can it improve gas mileage. And if one is driving up and down hills, OD should be off.
Old Mar 23, 2013 | 08:21 AM
Ham Bone's Avatar
Ham Bone
He's running 33s. So it actually might help. It would be like the stock ratio to tire size
Old Mar 23, 2013 | 12:57 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
driving in mountains and hills is fine to drive in o/d i have 300,000kms in the mountains in o/d original trans
Old Mar 23, 2013 | 01:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
While towing? And as a matter of fact, I believe even the owner manual tells you to turn off OD when going up big inclines, even without a load.
Old Mar 23, 2013 | 01:23 PM
Hahns5.2's Avatar
Hahns5.2
RPM isn't the only factor for gas mileage.
Old Mar 24, 2013 | 03:56 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
not that have found but even when towing I use od never have an issue
Old Mar 25, 2013 | 10:30 AM
Brian_'s Avatar
Brian_
your mpg will drop to a little under 10mpg with 4.10s. thats what i got when i used to have my 33s, before i upgraded to 35s and it dropped further to 8.7mpg.
