no idling
ok, ive replaced every sensor. on the truck
plenum replaced.
timing chain
water pump
radiator.
no vacuum leaks that i can find.
fuel pump replaced.
the truck will not idle. let go of the gas and it turns off.
I have no more ideas of what it can be.
The transmission is going bad. could this stop it from idling?
plenum replaced.
timing chain
water pump
radiator.
fuel pump replaced.
did you poke a wire through the little hole in the bottom of the IAC well on the back side of the throttle body to clean it out. it likes to get stopped up with gunk.
Trending Topics
Here’s an odd one. My sister boyfriend who has no mechanical exp made me feel extremely stupid. While trying to start the truck. He just happens to say. Man have you looked at the idle screw. Well it wasn’t even touching the throttle, a quick drill and a few turns its running again. At about 700 rpms.
and the good news my throttle body received one hell of a good cleaning
