Truck Camper Question
Old May 12, 2013 | 08:28 PM
Killerharen's Avatar
Killerharen
Default Truck Camper Question
What do you think is that the heaviest truck camper i could hold safely with my truck. I saw that the payload rating is around 1400 lbs with my truck but all the campers I found are heavier than that.
on a side note, could i pull a small trailer too if i get a camper?
Old May 13, 2013 | 08:38 PM
dhvaughan's Avatar
dhvaughan
are you talking about one of those big heavy slide-in campers?
you can do it, but i'd recommend some helper springs or replacement 6 leaf springs to keep the *** end off the ground.
how heavy are those things?
i'd think about 2000-2500 pounds of bed/tongue weight would be about the absolute max you'd want to try to haul. the brakes will be the weakest and most dangerous part of hauling that much weight. if you add a trailer - make sure it has trailer brakes or your really asking for trouble. the last problem is that a stock transmission will want to lay down and die if you overheat it, so you'll need to equip it with a big cooler, stay completely out of overdrive, and monitor your trans temp and run load range E tires.
to do it safely, you'd be better off with a 2500.
Old May 13, 2013 | 09:05 PM
Killerharen
Yeah those heavy slide in ones. Some run around 1500 lbs but they can get up to like 3000 lbs. I dont plan on getting one any time soon, it was just a thought. Looking around now, I'd rather get a 25' travel camper for the same price and have more than enough room.
Old May 14, 2013 | 10:41 AM
redneck_ram's Avatar
redneck_ram
you can easily tow a 30+ ft travel trailer with that truck. make sure you have a weight distribution hitch, and a brake controller.
we are getting a 32 footer to replace a 18 foot hybrid camper.
Old May 14, 2013 | 09:32 PM
DallasOregon's Avatar
DallasOregon
I have basically the same question. I have a 2500, and was looking at a camper that was 2360 lbs dry weight. I haul 2 jet skiis as well. OP, what camper are you finding that is so light?
Old May 15, 2013 | 08:12 PM
Killerharen
I found a smaller one on craigslist made for 1/2 ton trucks, I forget what it's called. I checked and some manufacturers even make truck campers for 1/4 ton trucks like the dakota and the ranger.
Old Jan 24, 2014 | 12:10 AM
Brucesterj's Avatar
Brucesterj
Wus sup Dallas..
I've got an '03 2500 CTD.. I've got an 11.5' fully self contained cabover that weighs 2700 alone.. add 40 gallons of fresh water, food, drinking water, bedding, clothes, small 45 lb. Honda gen, and other misc.. All of this easily 3200 lbs.. and with a pair of ride rite airbags pumped up to about 70lbs. Then I've pulled my 2200lb boat. It's a 3/4 ton truck and I like to make it work.
IDK... maybe it's my DIESEL that makes it haul more..?
-Bruce
Old Jan 24, 2014 | 12:55 AM
BBartow's Avatar
BBartow
Originally Posted by Brucesterj
Wus sup Dallas..
-Bruce
8 months later...
Old Jan 24, 2014 | 08:39 AM
Ham Bone's Avatar
Ham Bone
Wus sup Dallas..
-Bruce
No it's because you have a 2500 and air bags
Old Jan 24, 2014 | 07:19 PM
Brucesterj's Avatar
Brucesterj
Originally Posted by BBartow
8 months later...
HUH...? You quoted me.. and said something unrelated and I'm just trying to make sense of it..? "8 months later"..?
