Wiring an Accessory Power Outlet
Jul 11, 2013 | 01:15 PM
Jul 11, 2013 | 01:55 PM
Quote:
Originally Posted by
VWandDodge
OK, but do I wire the outlet straight to the battery? Connect the hot lead to the fuse, then to the positive and the black lead to the frame?
The problem is in bold.
That will work, or, you can find a switched ignition lead, so the outlet turns off with the ignition. Up to you.
Jul 11, 2013 | 08:39 PM
what color is your tractor ?
Jul 11, 2013 | 10:26 PM
dhvaughan
Poetic Justice?
Jul 12, 2013 | 08:44 AM
dhvaughan
Poetic Justice?
Man, you guys are s-l-o-w. It took posts to get to the important question.
Jul 12, 2013 | 09:22 AM
Is that a pressure treated 2x6 frame rail?
