My Dodge Ram...
Old Dec 22, 2013 | 08:41 AM
  #71
01-2500's Avatar
01-2500
I also used the dash from LMC truck: $300 well spent, IMO. You'll never find one in a junk yard. They screwed up the recipe for the plastic and they all cracked - even the ones parked inside and protected from sunlight. My bezel was cracked, too: another $100. So while I had it apart I put in a decent juke box (Kenwood). Had to replace front speakers, both were just not working, now driver's side has wiring issue I haven't diagnosed yet.
Reverse lights were intermittent - would work about 1 out of 100 times. I have a manual trans but my findings could apply to any. I had the trans out for clutch work, checked the switch with an ohmmeter - seemed OK. Checked the 12-volt feed with meter - seemed OK. Shorted the connector (the one on the truck wiring - not the switch) and the lights work. So when I put it back together I put a little piece of aluminum foil into each of the connector sockets on the reverse switch (to help make better contact between pins and sockets) Now the lights work.
Old Dec 22, 2013 | 05:38 PM
  #72
stewie01's Avatar
stewie01
^ Thread jack?
