Would this be impossible?
Old Sep 7, 2013 | 06:14 PM
95' 360 Ram's Avatar
95' 360 Ram
Default Would this be impossible?
http://www.carlisuspension.com/dodge...ominator3.html
I know it is for mostly 2500 and 3500 but would all I need to do is just the axle swap to make it work?
Old Sep 7, 2013 | 07:56 PM
snowboundrmk's Avatar
snowboundrmk
Are you looking at the 3" or 6" I believe the rear leafs won't work since they are 3" and yours are 2.5". You can just put the hangers and mounts off a 2500 onto your frame and then the 3" leafs would match up to a 60. And then do the front 60 to match. Shouldnt require anyvmodifications up front. They make great stuff although I'm not the biggest fan of radius arms.
Old Sep 7, 2013 | 08:00 PM
95' 360 Ram
I am looking at the 3". So it should work without having to extend anything, right?
Old Sep 7, 2013 | 08:37 PM
QuadCabLuv's Avatar
QuadCabLuv
im not sure on compatibility but i can tell you that those kings off road shocks are da shizzle. i drove a 05 silverado that had them with 6" lift and 35" knobbies and it rode like a cadillac.
Old Sep 7, 2013 | 09:56 PM
snowboundrmk
Shouldn't have to but that kit doesn't seem to come with control arms and I would recommend them
Old Sep 8, 2013 | 01:51 PM
merc225hp's Avatar
merc225hp
The 3" shocks will fit but the hole must be enlarged in the tower for clearance, the over the motor brace will not clear the master cyld it will have to be modded to work. $7000 for 3" of lift please come on, it's nice stuff but not $7000 nice.
Old Sep 8, 2013 | 02:00 PM
Seriously. A $3000 truck with a $7000 suspension. I could never justify that.
Old Sep 8, 2013 | 02:55 PM
95' 360 Ram
I plan on keeping this truck for life and doing a lot of upgrades. The lift kit is more at the end of the list with engine upgrades at the top (cylinder heads, cam shaft, ect...)
Old Sep 8, 2013 | 04:14 PM
Well unless you plan to take up desert racing, that suspension is way overkill.
Old Sep 8, 2013 | 05:15 PM
95' 360 Ram
I currently live in a desert and it doesn't look like i am moving any time soon.
