wet floors
Old Sep 17, 2013 | 10:10 PM
wyocountryboy's Avatar
wyocountryboy
Default wet floors
alright I used the search and nothing....I got a problem. it seems that both sides of my carpets get wet whenever it rains. i have looked for holes, rust, spots where it may have run down from the vent area....nothing. anyone experienced this? i have had this truck for around 2 months. i noticed it when i drove through a hellacious rain on my way to college.
Old Sep 17, 2013 | 10:21 PM
oxymoron29's Avatar
oxymoron29
You should have found tons of info on this if in fact you searched. Common places are the 3rd brake light seal and rear window seal (blocked weeps on bottom exterior seal cause slider track to overflow with water). I would check your windshield as well (was it replaced?). Pressurize the cab with the fan on full tilt for a few minutes with all the windows, doors shut. Start spraying all around the cab with soap/water solution and the leaks should show up.
Old Sep 18, 2013 | 08:06 AM
Old Sep 18, 2013 | 12:25 PM
wyocountryboy
thanks for the help fella's, I'll search more thoroughly next time.
Old Sep 18, 2013 | 01:53 PM
Hippo420's Avatar
Hippo420
mine leaks around the drivers door seal cause the door is tweaked a little for some reason
Old Sep 24, 2013 | 12:46 AM
Mopar Mike's Avatar
Mopar Mike
Could be coon ****..... Just sayin'... It's happened before.
