FireDodge's 360 Build
Old Mar 18, 2015 | 09:29 PM
  #191
Wh1t3NuKle's Avatar
Wh1t3NuKle
Get done already!! Wheeling season is right around the corner!! hhaaahaha
Nice progress
Old Mar 18, 2015 | 11:37 PM
  #192
FireDodge's Avatar
FireDodge
Nice progress
I'll be 300 miles from the wheeling truck this summer so progress will be stopped. Going to try my hardest to get the Cummins running so I can take it instead of my car this summer.
Old Mar 23, 2015 | 10:44 PM
  #193
tweeker909's Avatar
tweeker909
Originally Posted by FireDodge;323426 Finally got the rest of my used lift kit! I'll need to get some bushings and ball joints, but it's ready to go on when I can do it. You'll notice there are two sets of coils. One set is the Skyjacker 7" coils, the other is the RCD 6" coils. I'm going to run the RCD springs because they are a 1/2 ton coil and I can get more flex out of them.
[IMG
https://cimg8.ibsrv.net/gimg/dodgeforum.com-vbulletin/1024x576/80-20150315_191000_zpsq5xo56v5_c818a7ecf4a5cedf6bf3c3 bf1e588a4066df9f92.jpg[/IMG]
Also, this first picture is the truck the lift came off of. The owner is doing his own custom rock crawler build with it as you can see in the second pic. He cut 16" off the rear of the frame, Chevy leafs with custom shackles, Ford high pinion Dana 60 in the front with long arms and coilovers. The second pic is while he still had the old Skyjacker lift on the front, but his new setup on the rear.
rcd doesnt make a 6" 1500 coil fyi..the red ram has some serious outer edge tire wear.
Old Mar 24, 2015 | 03:55 PM
  #194
FireDodge's Avatar
FireDodge
I know the coils are a few years old. They came from a guy who wheeled with his 2000 1/2 ton.
Old Mar 25, 2015 | 10:11 PM
  #195
FireDodge's Avatar
FireDodge
New 40 over pistons and rings are on their way for the Cummins.
Old Mar 26, 2015 | 05:43 PM
  #196
tweeker909's Avatar
tweeker909
Just b/c the coils were in a 1500 dont make them 1500 coil b/c rcd has never offered them..Looking at your pics the skyjacker 2500 coil are very close to the same height and 2500 coil will be 2-3" taller then a 1500 of the same lift height which would put the rcd 3-4 shorter. With a heavy cummins you want the higher rated spring. rcd coils are 2500 coils if indeed there rcd.
Old Mar 26, 2015 | 06:05 PM
  #197
FireDodge's Avatar
FireDodge
I thought I mentioned it, but the lift will be going on the 1500. I'm just going off what I've been told so far as far as brands because I can't find any tags. The Cummins will be my tow rig work no lift other than its current leveling kit.
Old Apr 1, 2015 | 10:34 PM
  #198
FireDodge's Avatar
FireDodge
New pistons came in today. Cummins block will start getting machined tomorrow and I will hopefully have the short block assembled in about a week!
Old Apr 15, 2015 | 12:50 PM
  #199
FireDodge's Avatar
FireDodge
Block was machined a few days ago, crank was polished, new pistons assembled, and the head should be done today. Here's a pic of the block!
Old Apr 15, 2015 | 01:57 PM
  #200
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Nice! When you going to start assembling?
