The Camo Beast as it Evolves.
Old May 16, 2014 | 10:54 PM
  #91
aofarrell2's Avatar
aofarrell2
Originally Posted by corbo1962
Thanks, I think the light will come in handy when dove season gets here and you find yourself cleaning birds after dark. Stick a red cover or yellow cover to keep the bugs down
Maybe that's why they call them Mourning Doves
Old May 16, 2014 | 11:15 PM
  #92
tincan57's Avatar
tincan57
It makes a nice package for a sportsman (we have a good bit of hunting here). I have a strong bed cargo light in the farm truck, but nothing like this. Keep it up and you'll have to do a second battery.
Me, I'm thinking late night fishing (hose the bed down after cleaning the catch). Good upgrade! K.
Old May 17, 2014 | 08:03 AM
  #93
corbo1962's Avatar
corbo1962
Thanks! Yep, it would help night fishing. I've thought about a second battery. The ORE's came with a 135 amp alternator and I'll probably upgrade that to a 180 amp when it goes out.
Old May 17, 2014 | 08:07 AM
  #94
corbo1962's Avatar
corbo1962
There are plenty of morning dove around here... It can be a long morning getting your limit but the evening hunts it gets fast and furious and a limit can be knocked down in fifteen minutes, after a few cold beers waiting for them to fly
Old May 17, 2014 | 09:21 AM
  #95
aofarrell2's Avatar
aofarrell2
If you get a second battery it goes without saying that you should get a battery isolator. A lot of these newer isolators have a anti-drain mechanism or whatever they call it, so if one battery fails it won't drain the other.
135 amp alternator on your 2nd gen? didn't know such a thing existed...
You could go with dual alternators Been done before. That way if one fails you still have the other
Old May 17, 2014 | 11:07 AM
  #96
corbo1962's Avatar
corbo1962
The 135 amp alternator was a perc on the off road edition. I agree, with a second battery, an isolator is the only way to go. Dual 135 amp alternators is something to consider, thanks for the suggestion! A long pull with my 12,000# winch would be very draining on the system.
Old May 17, 2014 | 11:36 AM
  #97
Spillage's Avatar
Spillage
Mine came with the 136amp Alt as a part of the tow group package.
AHC Trailer Tow Group
ADJ Heavy Duty Service Group
BAZP 136 Amp Alternator
Old May 17, 2014 | 11:59 AM
  #98
aofarrell2's Avatar
aofarrell2
Just use the voltage regulator off of the older Chryslers, I can get you diagrams and P/Ns for it later. IIRC you can run one alternator off of the PCM and the other with the VR. I will have to double check on that though.
Old May 17, 2014 | 01:21 PM
  #99
corbo1962's Avatar
corbo1962
I stand corrected, mine is a 136 amp, I guess my memory got a little fuzzy and I lost an amp.. Lol
Old May 17, 2014 | 01:23 PM
  #100
corbo1962's Avatar
corbo1962
Yes, that sounds like the way to go, if I do it, I'll hit you up for the correct info. Thanks
