The Camo Beast as it Evolves.
Old May 20, 2014 | 10:22 PM
  #111
Wh1t3NuKle's Avatar
Wh1t3NuKle
Dude, your kids must have been stoked that you packed the sun up in the truck!! hahahah
You're not wheeling hard enough....you still have the exhaust tip sticking out the quarter panel!!
Old May 21, 2014 | 08:08 AM
  #112
corbo1962's Avatar
corbo1962
The exaust tip are good but the muffler has crackes at both ends for the tips hitting stuff. I'll get that redone when I install the traction bar and exaust headers. My daughter is pretty excited about the lights.
Old May 31, 2014 | 08:30 PM
  #113
corbo1962's Avatar
corbo1962
I ordered a 3" body lift, it should be here next week. Not sure when I have the time to install it. Once it's installed, I guess I'll get started on bumpers.
Old May 31, 2014 | 08:50 PM
  #114
Wh1t3NuKle's Avatar
Wh1t3NuKle
Yeah Buddy! I'll tell ya....it's a fun install. Most favorite part was the column shifter.
Old Jun 1, 2014 | 01:58 AM
  #115
corbo1962's Avatar
corbo1962
What is special or fun about the column shifter.
Old Jun 1, 2014 | 06:01 PM
  #116
Wh1t3NuKle's Avatar
Wh1t3NuKle
I misspoke, but slightly. It's the connecting rod between the transmission and the column shifter arm. Both in the engine bay, nicely tucked behind the brake booster.
That rod has to be removed, you'll love the grommets that hold it in on both ends. Take note of how it is installed beforehand to retain the clocking position. You have to cut it and weld a piece in to extend it. Again, maintain the clocking position so the ends are not oriented correctly otherwise you may not hook it back in. I didn't have this problem at all, but still like to mention it bc you can quickly mess it up once cutting it.
I used angle iron with clamps to keep both pieces straight and clocked properly. The rods clamped tightly into the corner.
Old Jun 1, 2014 | 06:45 PM
  #117
Johnn123's Avatar
Johnn123
Oooo cant wait to see! What route are you going for the bumpers Corbo?
That sounds like a terrible PITA to me. Good note for people to see though for the DIY'ers!
Old Jun 1, 2014 | 07:37 PM
  #118
corbo1962's Avatar
corbo1962
Thanks for the info. I figured that the linkage would have to be lengthened. I would imagine that if the orientation wasn't exact, it would have to be redone. I will make sure that it is evaluated completely before the first cut. Good tip!
How about the transfer case shifter? I haven't looked at it lately. Does it pivot off the frame or the body? If the frame I'm thinkin that it dropping down 3" would cause many problems. What did you do here?
Old Jun 1, 2014 | 08:05 PM
  #119
corbo1962's Avatar
corbo1962
[QUOTE=Johnn123;3170611]Oooo cant wait to see! What route are you going for the bumpers Corbo?]
I think I'm gonna start with 3" driveshaft tubing like the roll bar. There will be 1 piece on both front and rear that gets tucked as tightly to the truck as possible. Then probably 2.5" to 2" to drop down and contour on the front with the winch being tucked in on the front between the two. I think I'm going to try and stick a couple of shorty flood LED light bars flush in the angled sides, To throw light off into your turning. On the back, I will copy WK and raise the receiver up and the same size lower bar from the front, I'll trim the rear in a simular fashion. At least thats the direction i'm thinkin now. Not sure how I'm going to do the rock sliders and steps on the sides yet. Kinda thinkin about putting 1" receivers in the sides of the rock sliders and making the steps removable for when you go extreme.
Old Jun 2, 2014 | 05:16 PM
  #120
corbo1962's Avatar
corbo1962
Not much will happen this week on the truck. The temp will hit a high of 108 deg and most of the week will be 105-107.
