Gas Tank Question
Old Oct 10, 2014 | 11:19 PM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Default Gas Tank Question
So I've got a gas tank question.
I had a 1997 Dodge Ram Extended Cab Long Bed, it had a 35 gallon gas tank. Currently, I have a 1997 Dodge Ram Extended Cab Short Bed with a 26 gallon gas tank. I still have the 35 gallon tank from the other truck, and when I swapped out my fuel pump, I tried to use the 35 gallon tank, but it wouldn't work because there was no where under the truck to connect the front strap. Is there a larger gas tank that would work on an Extended Cab Short Bed? Is this old 35 gallon tank of any use?
Thanks! I just have this extra tank and don't think I can do anything with it.
Old Oct 10, 2014 | 11:21 PM
stewie01's Avatar
stewie01
Custom fab a strap? Or sell it on craigslist.
Old Oct 11, 2014 | 01:44 AM
Thornloe Pride's Avatar
Thornloe Pride
If it doesn't work, make it work! I'm sure there's a way to do it.
Old Oct 11, 2014 | 07:27 AM
1997JollyGreenGiant
I think I'm going to go walk around a junk yard and see what I can find. I think I read that the EC/SB Ram 2500 had a 34 gallon tank and the Long Bed 2500 had a 35 gallon tank. I'll have to see if that's true and if the 34 gallon tank straps up the same as mine.
Old Oct 11, 2014 | 01:13 PM
BBartow's Avatar
BBartow
The 34g was an option in the later years I believe.
Old Oct 11, 2014 | 08:06 PM
tincan57's Avatar
tincan57
Well, my former 97 Regular cab long bed Ram 2500 gas 360 4x4 Dodge build sheet had it with a 35 gallon tank, (and it had one). K.
