Failed at Mud Bog due to lack of HP....
Old Oct 12, 2014 | 12:51 AM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Failed at Mud Bog due to lack of HP....
I ran in the local mud bog yesterday. I dropped down to a set of 36" X12.5" bias ply tires to run in a more appropriate group. The problem is, I didn't finish. I got stuck at 157', 43 feet from clearing the pit. After talking to my family who were spectating, they said my tires weren't spinning fast enough to clean the treads. I ran in 4Low, 3rd gear. I tried 4th gear but the engine couldn't spin my tires, so I dropped back down. I wanna know how to boost my horsepower. Now, mind you, my poor 318 is really tired. My vacuum is so low, the vents on my heating/ac system don't switch. The reason I got this far is I installed a 4X4 Posilock kit on my front axle, because last year my vacuum actuator gave out under full throttle. My current plan is either a Cummins turbo and intercooler or a 390 stroker. Any thoughts?
Old Oct 12, 2014 | 01:07 AM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Are you still running stock gearing? If you do then your little 5.2 may not be as tired as you think it is. Try running 4.56 or 4.88 gears and you will get some power back. If you really want to do it right swap out your stock axles for Dana 60 front and rear. Then also swap out your 5.2 for a 5.9 that you have stroked to a 408.
Old Oct 12, 2014 | 04:13 PM
charlie1935's Avatar
charlie1935
This will power it up!
Couldn't get picture to work.
Old Oct 13, 2014 | 09:33 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
stroked 360 to 408 if you stay mopar. otherwise, LS1 swap. This assumes you already have knowledge about axle gearing.
Old Oct 13, 2014 | 10:29 AM
Ham Bone's Avatar
Ham Bone
Ban him!!!!
Old Oct 15, 2014 | 06:42 PM
BrandonBuc'em's Avatar
BrandonBuc'em
+1 ban him
Old Oct 16, 2014 | 10:01 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
this thread should have been banned from the start.....
Old Oct 16, 2014 | 12:29 PM
It is kinda lame....seeing how there are probably 5000 existing threads on how to increase horsepower....
Old Oct 16, 2014 | 01:36 PM
ChillyPhil's Avatar
ChillyPhil
Don't fear the gear.
Go 4.88s.
Old Oct 16, 2014 | 05:38 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Go 4.88s.
Did you go to 4.88 now like you've stated previously?
