Rear axel steer?
Old May 29, 2016 | 01:02 AM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by Spillage
Though it could be, I don't think it is dependent on differential braking in this case.
Closing in on 200k, I'm sure there are plenty of bits coming due for replacement.
Kinda sounds like you've already talked yourself into an end to end suspension bushing replacement already.
Ultimately, if the truck's a keeper, it's worth doing regardless of whether or not it solves your immediate problem. I haven't done mine yet, but it's something I do to any vehicle more than 15 years old that's worth keeping. It makes 'em just a tad harder to wreck.
Old May 29, 2016 | 11:20 AM
Spillage's Avatar
Spillage
Yup, a full bushing replacement is on the radar at 197k, but so is full steering components, axle rebuilds, trans rebuild, engine rebuild, etc, etc.
At this mileage I'm feeling lucky to have not had to do anything sooner.
I just need to work out where to spend the limited trickle of funds first.
Old May 29, 2016 | 11:30 AM
Spillage's Avatar
Spillage
Have someone follow you down the road, that KNOWS what you are going to be doing. Have them check to see if your 'tail is wagging'. does the truck change its 'angle of attack' when applying the brakes? Does it dog-track when not on the brakes??
I could see bad bushings doing that...... but, I would think it would make some noise too. But, not like I have never been wrong before.
From the cab it does feel like the back end is pushing out to the right.
I was thinking of putting a camera on the bed (looking at the wheel) to see if there is anything obvious.
Old May 29, 2016 | 11:33 AM
Wonder if that is something you could test in the driveway??
