and the saga begins...... HFIAG 5409
Old May 31, 2016 | 10:12 PM
Check the connector for the one-wire sensor. Make sure it has a good connection, and make sure the sensor grounds to the manifold good.
You can pick up an Infra-Red temp sensor (little gun like feller) and point it at the top of the thermostat housing, to see what temp it REALLY is.
Old May 31, 2016 | 11:22 PM
Friar Tuck's Avatar
Friar Tuck
Take all that stuff off the top of it. I can't see it!!
Old May 31, 2016 | 11:24 PM
Friar Tuck's Avatar
Friar Tuck
What temp tstat?
Old Jun 1, 2016 | 12:49 AM
odzmaker's Avatar
odzmaker
Originally Posted by friar tuck
what temp tstat?
192.5
Old Jun 1, 2016 | 12:56 AM
odzmaker's Avatar
odzmaker
I'll try removing the sensor and getting the sealant off . makes me wonder what the other sensor is telling the PCM though.
It hasn't thrown any codes yet and seems to be running ok .
Old Jun 1, 2016 | 08:50 AM
The other sensor is two-wire, it just modifies a signal from the PCM, so, that one is prolly working as it should.
Old Jun 1, 2016 | 05:14 PM
odzmaker's Avatar
odzmaker
Well , It finally threw a code #1 miss fire.
All ignition parts are brand new,changed them while I had the intake off.
When I pulled the old plugs #1 was in awful shape like half of the ground electrode had been eaten away.
Gona do a comp.test after the engine cools off for a minute. But I'm starting to think its time to shop for a set of heads (cause if I'm changing the gasket I'm not putting the old ones back on) Sigh.
Old Jun 1, 2016 | 05:27 PM
Odessa, or Clearwater make NEW heads, that are better castings than stock. They are regularly for sale on Ebay.
Old Jun 1, 2016 | 06:29 PM
odzmaker's Avatar
odzmaker
1: 120 psi 2: 90 psi
3: 90 psi 4: 125 psi
5: 110 psi 6: 110 psi
7: 90 psi 8: 95 psi
So now I'm starting to think.. ( hell i don't even know what to think anymore) bad Injector ? still no solution on temp yet either. ( wonder if the army surplus has any C-4 in stock)
Old Jun 1, 2016 | 08:35 PM
Now do a wet test. Put a tablespoon of oil into each cylinder, and test again. See what the numbers do.
