1999 ram 1500 46re mount from bell housing to frame??
Old Oct 6, 2016 | 01:33 PM
Blkram1999's Avatar
Blkram1999
Default 1999 ram 1500 46re mount from bell housing to frame??
I looked under my truck and noticed i saw a picture and mine was off. The mount thaf loomes would bolt up to the frame is gone/missing is it supposed to be there. And also the dust cover is gone i didnt know it was supposed to be there. And also the driver side motor mount is missing the read bolt that bolts it to the block. The truck must have been pieced together before i got it but it is so nice and clean for its age. I need opinions
Old Oct 7, 2016 | 10:35 AM
There is no mount from bellhousing to frame.
Easy to replace the stuff that is missing. Assuming you don't have a bunch of broken bolts. Just grab what you need from the local wrecking yard.
Welcome to DF!
Old Oct 7, 2016 | 06:29 PM
Blkram1999's Avatar
Blkram1999
Thanks for the reply and welcome. I am curious what is missing from my trans then. There is a place on the trans driver side that has a metal bracket of some sort that is next to the shift links and tv cable. It appears is picturea on the internet that it holds the trans to the frame and i have the bracket from starter location that goes to the side of the block thats missing. If i could i would up load a picture but i am using a pos phone to be on here. You think its ok to keep driving for a while until i get time and everythin to go pull used parts?
Old Oct 7, 2016 | 09:28 PM
Blkram1999's Avatar
Blkram1999
I figured out the bracket that looks like it would bolt to thr frame in pictures is the shift link bracket. You were absolutly right about no frame mount to bell housing.
Old Oct 7, 2016 | 09:32 PM
Blkram1999's Avatar
Blkram1999
And after searching and searching i found out its the starter side trans to block strut
Old Oct 8, 2016 | 08:55 AM
Coolness.
