replacement body parts
well, i sent my truck off to get the rust on the doors repaired the other day. i also noticed a little bit of surface rust peeking on the rockers from underneath the running boards. Turns out my baby needs some love. really only the front 8" of the rockers are bad, and 2 very small holes in the cab corners. also a couple small holes in the rear wheelwells and rear of the front fenders. However, since im fixing it, im doing it right.
where is the best place to order replacement body parts from? I know of LMC but their prices seem to have jumped quite a bit since the last time i looked. Im wondering if there's other/better places to order from.
I am going to do just about everything thats bad so here's the panels i need:
- front fender patch panels behind the front wheels
- outer rocker panels
- cab corners
- full bedsides
are all of the replacement panels the same from vendor to vendor? is one brand heavier gauge than another? are they the same thickness as oem?
I plan on repairing the body next spring so i'll slowly accumlate the parts until then. At the same time i will replace the front fender flares since the passenger side is cracked, fill a few small dings, remove all rock chips in the rear fender flares, and repaint the entire truck.
- cab corners
- full bedsides
I didn't know amd made panels for our trucks. I will look into that.
If amd doesn't have what you need try...
https://www.shermanparts.com/ecat/base/index.php
or
http://www.autobodyspecialt.com/cgi-...i?display=home
or
