Instrument Cluster Bezel removal...
Old Sep 22, 2017 | 06:40 PM
Ivon's Ram's Avatar
Ivon's Ram
Default Instrument Cluster Bezel removal...
1998 Dodge Ram 1500 Laraime....I'm changing the out the broken cupholder and need to get at the two screws underneath the bezel. Any suggestion's on the best way to remove the bezel without breaking the connecting smaps?
Old Sep 22, 2017 | 07:42 PM
Pry GENTLY, do NOT use metal tools. Start in one corner, and work your way GENTLY around, a little bit at a time.
Welcome to DF!
Old Sep 23, 2017 | 10:13 AM
Ramman18's Avatar
Ramman18
Drop the tilt wheel all the way down. You can cover it in painter's tape to add support. You can try your best to be careful but if it's gonna crack, there's nothing you can do except order the LMC bezel.
