01 ram 1500 starting problems
I have a 01 ram 1500 5.9 L that after you have driven it all day it has problems starting is giving me a code P 1391 which is the crank sensor I have already changed the crank sensor and it is still giving me the same code any suggestions on what it might be
Where did you get your crank sensor from, and what brand is it?
That code also refers to the cam sensor as well. It's under the distributor cap. Parts store will likely refer to it as "pick-up coil".
