Wholesale lot special frustrations
Old Mar 5, 2018 | 10:59 AM
BrokeBolts's Avatar
BrokeBolts
point taken....
Old Mar 5, 2018 | 02:22 PM
BrokeBolts's Avatar
BrokeBolts
Huh....these rear brake lines have wire wrapped around them, kind of like I spring. Haven't seen that before. Is that original equipment? Left side was pretty easy, right side looks like it may be a challenge, screwed down into a couple brackets onto the axle.
Old Mar 6, 2018 | 09:28 AM
Yep, that's stock. The wire wrap is to make sure that moisture and road salt are held against the steel lines, so they corrode away quickly........ Use the copper/nickel stuff as replacement line, it lasts a LOT longer.
Old Mar 6, 2018 | 09:37 AM
BrokeBolts's Avatar
BrokeBolts
The guy at Advance tried to sell me a 50 foot roll, no fittings, for $120,found 25 feet on Amazon, with the fittings, $21.....One side was easy, the other looks like it may be a challenge, I'll get it figured. I'm starting to think a lot of this stuff hasn't had any attention in 20 years. Found that the e brake cable is frayed, not expensive, just more work and expense. I don't know if it will at least pass inspection in that condition, and could do it in the later spring or summer.
