Tire size question
Old Aug 23, 2020 | 12:01 PM
Big Hat's Avatar
Big Hat
Default Tire size question
I have a 2002 Ram 2500 Quad Cab 4x2 with an 8’ bed and a 5.9L Cummins engine, and I plan on it being my daily driver for at least another 7 years.
Currently my tires are 265/70r16, and the door jamb sticker lists 245/75r16 as the stock size. I’m going to buy tires in the next month or so and am planning on buying an all-terrain tire to help address my getting stuck problem. I live in the woods and this truck can get stuck in wet grass. I understand the root of the problem is a heavy front end and a light back end.
My question is, am I better going back to the stock tire size and (slightly) increasing the weight/contact-area ratio on the back end, or sticking with the wider tires for the decreased weight/contact-area ratio in the front end.
Also, does anyone have any experience with Sumitomo Encounter AT tires?
Old Aug 23, 2020 | 01:59 PM
Run a build sheet for your truck from here. (equipment listing) That will show you what size tires your truck actually left the factory with.
Changing your tire size probably won't make all that much of a difference, changing the tread pattern, on the other hand, most certainly will.
Old Aug 23, 2020 | 04:30 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
All terrians really suck in the mud they are really good in the snow
Old Aug 25, 2020 | 02:47 PM
KillerLemming's Avatar
KillerLemming
Personally I like my general grabber at/x 265/75/R16.. I've never gotten stuck, even when the tread was getting low
Old Aug 25, 2020 | 11:21 PM
2bit's Avatar
2bit
300 pounds in the box would help and probably make it ride better.
