Squeak in steering column anybody else have it?
Old Jun 15, 2021 | 05:59 PM
triflex's Avatar
triflex
Default Squeak in steering column anybody else have it?
2001 Dodge 2500, 5.9, 208, 000 miles, stock...squeak in steering column I cannot find...I can raise up on the steering wheel and it stops until I release it...push the shift lever down and it helps but doesn't completely stop it...I'm baffled...Tx for your reply
Also the upper part of the tilt moves as well but not much...steering wheel does not have slack side to side just up and down...
Old Jun 15, 2021 | 06:11 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Probably the upper bushing (behind the wheel is bad)
Old Jun 15, 2021 | 06:20 PM
triflex's Avatar
triflex
Tx...I will check that.
Old Jun 15, 2021 | 08:43 PM
MoparFanatic21
If it is that you need a whole new steering column. Dodge never offered that as a part
Old Jun 16, 2021 | 05:32 PM
triflex's Avatar
triflex
There is an engineering company that has it on Ebay...
Old Jun 17, 2021 | 12:11 AM
MoparFanatic21
Never have I found one that fit. I have tried. There is so a bearing behind it that tends to go bad
Old Jun 17, 2021 | 11:30 AM
triflex's Avatar
triflex
So, there is a bushing that's not available and behind the bushing is a bearing?...hummnnn...Tx for the reply.
Old Jun 18, 2021 | 12:17 AM
MoparFanatic21
I did see a YouTube video where a guy replaced the bushing a bearing. Never gave part numbers. He said his local parts store cross matched the bearing and the bushing he said he bought. I have tried 4 bushings in another column and none of them fit.
If you do find out what works PLEASE post them here
Old Jun 18, 2021 | 08:28 AM
triflex's Avatar
triflex
I will be searching and if/when I find them I will definitely post for all...Tx for the reply.
Old Jun 18, 2021 | 10:52 PM
MoparFanatic21
Anytime
