mystery box of unknown function
Old Jul 29, 2021 | 01:38 PM
meehere's Avatar
meehere
Dorman - OE Solutions 628-040 from walmart.com of all places. Does not fit like origional, placed pad starting behind bull rings to rear. Hope this works. have not completed wireing at this time but intend to wire into existing. Origional plug is 4 wire, 2 to seat, 2 to back pad. Prepairing to hack and slash right now. think I have everything I need to make this happen. If it works, can't complain for just under $40 and I have an extra pad from the deal. The bull rings and pliers they supply don't work, as I replaced the cover, I used the original rings to reattach the cover. If you want more of the gory details I will provide.
Old Jul 29, 2021 | 09:09 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
If you get it working please post how you did. I need one for my passenger side but I couldn't figure out how to get it to work. I know one plug goes to the internal diode that tells it the temperature and the other to the wires in the pad.
Old Jul 30, 2021 | 12:35 AM
meehere's Avatar
meehere
Err, where is the diode. still have old pad, kinda shame, Had a connection pull out in the pad. My progress is (drum roll) the white and grey wires go to the back. the 2 black with red tracer (stripe) go to the seat. Got a problem thou, the impedance of the seat seems to be 4.3k ohms for stock. the dorman is not measurable with cheap multi-meter which seems to be the same as the back. The passengers set works fine, drivers set still blinks the low heat light as it did when the pad had open circuit. have checked, seat is not open circuit. any ideas? mein is to get resister to match origional.
Old Jul 30, 2021 | 10:18 AM
MoparFanatic21
According to the fsm it's somewhere in the bottom seat heater pad and tells the module what temp the pad is at. If you can figure out the resistance of the Dorman pad you could either add a resistor
Old Jul 30, 2021 | 11:06 AM
meehere's Avatar
meehere
Where might I obtain an fsm ( not sure what fsm is but sounds good to have). Will dig into the old pad to see what treasures are there.
Old Jul 30, 2021 | 11:42 AM
MoparFanatic21
fsm is the Factory Service Manual it is whet Dodge techs use when you take the truck in for service. You can download it from the FAQ section of the forum.
Old Jul 30, 2021 | 01:35 PM
meehere's Avatar
meehere
Any chance you could post link? I am not very good with the social media and have not had luck finding the fsm. Thanks in advance.
Old Jul 30, 2021 | 04:09 PM
Spillage's Avatar
Spillage
Originally Posted by meehere;[url=tel:3521205
3521205[/url]]Any chance you could post link? I am not very good with the social media and have not had luck finding the fsm. Thanks in advance.
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Pick your year.
Old Jul 31, 2021 | 04:39 PM
meehere's Avatar
meehere
Maybe this should be posted in another thread but thank you to all for the help. have frankensteined a cable and now the seat heater works! When you replace the heater pad keep the old one. Use a light to find the temp sensor in the old pad. In the blue connector you will find 2 black wires with red tracers(?) a grey and a white wire. check the sensor by testing the resistance acros the black with red tracer wires, should be about 2kohms. The sensor was located in my pad off center about 1/2 - 1 inch from the oblong box you will see where the wire enter the pad and as I recall on the side of the wires tested. It will appear as a dot about 1/4 -1/8 " in diameter. I cut the blue connector with most of the wires from the pad. Rewire the cables so the heating pads back and seat are in series acorss the white / grey connections. I added tails to the sensor, shoved it into the seat on top of the pad and connected to black with tracers in plug. Polarity did not seam an issue. When done, fired up the truck and turned on the heater, go nice toasty buns. Will know more about positioning of sensor later this year.
Old Jul 31, 2021 | 06:07 PM
MoparFanatic21
Can you explain better?
