mystery box of unknown function
Old Jul 28, 2021 | 01:15 PM
meehere's Avatar
meehere
Question mystery box of unknown function
02 ram 3500 vin c power seats, heaters, windows, slt interior. Have removed drivers seat for repair (not easy, for bolts my foot) and removed center seat required. Found white box with electronics attached to seat plate. Any ideas what it does? Is it an alien device to mark the previous owner as already abducted? A government box to cause the truck to return home when commanded? My chrysler dealer has no idea. search of number on connector returns nothing.
Attached to bottom of center seat
Old Jul 28, 2021 | 02:55 PM
Seat belt module. That's normal.
Old Jul 28, 2021 | 03:51 PM
meehere's Avatar
meehere
Smile
Thank you for info. Can I just short wires in plug to get light off dash as the switch in the drivers buckle has a problem and the light comes on periodically?
Old Jul 28, 2021 | 04:06 PM
I think it does more tricks than just that though. You *might* be able to trick it into thinking the switch is close with a jumper though... Get a service manual for your truck from here, wiring diagrams are in section 8W. See if the switch in the buckle is normally open, or normally closed.... (or, use a meter to test that aspect of it all.....) and jumper/cut as necessary.
Old Jul 28, 2021 | 04:31 PM
meehere's Avatar
meehere
Any Idea where this box appears on the diagram? As with most diagrams I have found, The location is a guessing game if not obvious like head light. And as usual no 02. But thank you, should provide some help.
Old Jul 28, 2021 | 05:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Not the seat belt module, it's s the heated seat module. Seat belt module went away in 99
Old Jul 28, 2021 | 05:50 PM
I do believe you are indeed correct.
Old Jul 28, 2021 | 09:32 PM
MoparFanatic21
Only reason I know is because of my heated seat swap
Old Jul 28, 2021 | 10:54 PM
meehere's Avatar
meehere
Good to know as I just replaced the bun warmer in the drivers seat along with the seat cover
Old Jul 28, 2021 | 11:04 PM
MoparFanatic21
Where did you get the heating pad?
