Kenne Bell Supercharger
Old Nov 22, 2021 | 10:48 AM
corsair231's Avatar
corsair231
Default Kenne Bell Supercharger
I have a 97 Ram, 5.9 SS/T with a Kenne Bell supercharger. Yes, it's an ancient beast and there-in lies the problem. I've got the larger, 6 lb pulley. I'm looking to upgrade to the smaller 8-10 lb pulley but I cannot find one anywhere. Kenne Bell no longer services these kits and I cannot even get a response from them on it. All of the places that I have checked that specialize in supercharger pulleys, don't show anything for Kenne Bell products. Anyone got a line on a pulley or where to get parts for this dinosaur?
Thanks
Old Nov 22, 2021 | 07:07 PM
Direct from the source is probably about the only option, unless you get really lucky. Might try calling them on the phone, and see if you have and better success.
Worst case, take your current pulley to a machine shop, see how much they would charge to make up what you want.
Old Nov 22, 2021 | 08:19 PM
adukart's Avatar
adukart
You can also check jon bond performance. He occasionally gets parts for them. I have a small pulley for the kenne bell on my Shelby durango. Still only make 7psi up top. The small pulley makes 9psi at 3000 rpm and falls off. The manifold set up that feeds the blower is terrible. Someone used a mod man intake an mounted it directly on the intake and made a custom feed with an srt10 throttle body. He made 14psi on the big pulley just by feeding the blower like that. I would make a custom feed for the blower, that's the way to do it. You could also try an 8 rib. It will look goofy having an un-occupied rib but that may be your only option.
Old Nov 22, 2021 | 09:31 PM
corsair231's Avatar
corsair231
Originally Posted by adukart
I have a small pulley for the kenne bell on my Shelby durango. S.
What is the pulley diameter?
Thanks
Old Nov 25, 2021 | 02:11 PM
adukart's Avatar
adukart
Originally Posted by corsair231
what is the pulley diameter?
Thanks
2-5/8"
Old Nov 26, 2021 | 05:26 PM
corsair231's Avatar
corsair231
Thanks, I appreciate your help.
Old Dec 1, 2021 | 11:02 AM
gabbyRose's Avatar
gabbyRose
You can also check jon bond performance. He occasionally gets parts for them. I have a small pulley for the kenne bell on my Tutuapp 9Apps Showbox Shelby durango. Still only make 7psi up top. The small pulley makes 9psi at 3000 rpm and falls off. The manifold set up that feeds the blower is terrible. Someone used a mod man intake an mounted it directly on the intake and made a custom feed with an srt10 throttle body. He made 14psi on the big pulley just by feeding the blower like that. I would make a custom feed for the blower, that's the way to do it. You could also try an 8 rib. It will look goofy having an un-occupied rib but that may be your only option.
I agree , good interpretation
