new wheels and tires
Old Dec 16, 2022 | 05:21 PM
kidwitha2ndgen's Avatar
kidwitha2ndgen
Default new wheels and tires
i just put a 2 inch leveling kit and what bigger tires to fill out the wheel well and if I'm right i can fit 35 inchers in with no problems should i keep the stock 15 rims and just put bigger tires or get a whole wheel and tire set. if that ten what size, I sorta want to keep it old school with the 15s but if there is some reasons 20s would be better or and other size I'm just using that as an example I would love to know
Old Dec 16, 2022 | 07:28 PM
What are you driving? 2nd gens never came with 15's, 16's were stock. If it's a half ton, 33's would likely go rather nicely with your 2" level. I think 35's would rub in various places. Unless its a 2500.... then they might fit even without the level.
Something else to keep in mind though, if you have the stock 3.55s gears, 33's are going to turn it into a dog. 35's will be worse..... and re-gearing ain't cheap.
Old Dec 19, 2022 | 05:39 PM
kidwitha2ndgen
sorry that was a typo I meant 16's and thank you again for the advice and no it is a 1500 so ill probably go with the 33s thank you
Old Dec 19, 2022 | 05:50 PM
See what gears are in it now. You might get a pleasant surprise.
Old Dec 21, 2022 | 01:05 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I upgraded to 17" to keep the old school look and it is also easier (and cheaper) to find tires even used
