Spark Plug Woes
Old Apr 1, 2007 | 10:03 PM
Kelse's Avatar
Kelse
Default Spark Plug Woes
Hello
I am a new Dodge owner , 2001 1500 318 4x4 short wheel base,,
Attempted to change spark plugs,, however one of the eight plugs would not accept wrench,,, the plug itself is surrounded by a heat shield that plug wire sort of snaps into,,
My question is,, can these shields be removed and how are they removed ??
Thank you
Kelse
Old Apr 1, 2007 | 11:12 PM
jalapeenoz's Avatar
jalapeenoz
Default RE: Spark Plug Woes
I had a 01 318 that I changed the plugs on a couple of times. Just need a good spark plug socket and long extension to get down in the heat shield. I believe you can pull out the shields with pliers, but I never had to (nor did I want to). Changing those were a breeze compared to my 4.7.
Old Apr 1, 2007 | 11:43 PM
dhvaughan's Avatar
dhvaughan
i removed mine. just grab them on the end with a pair of pliers and twist them back and forth.
those shield trap dirt and sand, so before removing plugs its a good idea to blow them out, otherwise the dirt falls down in the cylinders.
