Fuel Economy!!!!
Old Apr 2, 2007 | 10:41 AM
19Ram99's Avatar
19Ram99
Default Fuel Economy!!!!
Okay so I ran my first tank of gas through my 1999 Dodge Ram 1500. The truck is stock with the exception of a catback Flowmaster exhaust. I was able to get 204 miles out of a tank and when I filled it back up, it took 22.6 gallons and that equals out to 9.02!!! WTH!!! I mean, I knew Dodge's didn't get the best but under 10 mpg is rediculous. The motor is a 5.2L, thank god I didn't get a 5.9!
Any suggestions?
Thanks!
Old Apr 2, 2007 | 11:20 AM
HankL's Avatar
HankL
Default RE: Fuel Economy!!!!
a very long read
but with dozens of 'real' ideas on how to improve MPG on Rams:
https://dodgeforum.com/m_447500/tm.htm
Since your truck is new to your ownership
suspect the catalytic converter being partially plugged
(very common on Dodges and there is a factory recall)
and/or some of the oxygen sensors being 'poisioned'
by sulfur in gasoline or metals from burning lube oil
(also very common, as are poisioned fuel tank level senders)
Old Apr 2, 2007 | 11:33 AM
19Ram99's Avatar
19Ram99
Thanks for the info. Can I just take the truck to a Dodge dealership and they will replace it?
Old Apr 2, 2007 | 12:55 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Damn, you need some serious maintenance on your 5.2. Read up on my engine build in my sigline. I typically get 15/16mpg on the highway (not loaded) and about 12/13 when hauling my trailer; however, on a recent trip from Illinois to Canada, I was eeking out 9mpg hauling this old VW bus.
Old Apr 2, 2007 | 01:34 PM
99Ram360's Avatar
99Ram360
now keep in mind that i just put it on, i installed a MSD blaster ignition box and i was suprised when i filled up and it only took me 4gl. to go 67 odd miles on the freeway and that comes out to 16.75 mpg. the truck is a 1999 ram with a 5.9L . hope it helps
Old Apr 2, 2007 | 01:41 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: VWandDodge
I get 19-21 with my 93 ctd empty!
thats cummins turbo diesel man!
19Ram99 - sounds liek you should disconnect the battery for 15 min or so allowing the computer to reset. top it of with good fuel (no arco, 7-11, etc). then drive it like you intend and the com,puter should learn anew.
VWand Dodge...still got air cooled??? stop on by and see us at www.azbaja.com or our friends at http://www.chircoestore.com/catalog/smf/index.php. aircooled all the time.
Old Apr 2, 2007 | 01:46 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Still air-cooled. Got a 1965 Beetle that is the next project. I was hauling the Bus for a friend.
Old Apr 2, 2007 | 04:09 PM
don_ripley's Avatar
don_ripley
Welcome to driving a Dodge Ram.
Old Apr 3, 2007 | 12:57 AM
TMS Bill's Avatar
TMS Bill
Mileage that bad points towards leaking plenum or clogged cat.
Old Apr 3, 2007 | 12:53 PM
19Ram99's Avatar
19Ram99
I will check both of those. Any diagrams or anything on the plenum?
