Removing ground effects
Old Apr 5, 2007 | 08:00 PM
IndyRamMan's Avatar
IndyRamMan
Default Removing ground effects
Iv been contemplating removing my ground effects. Is it mostly just 3M tape or something? Will it hurt my paint whenI take it off? Any paint safe adhesive remover I can use? How much does the whole kit weigh? thanks.
Old Apr 6, 2007 | 01:38 AM
Chopper1's Avatar
Chopper1
Default RE: Removing ground effects
Unless it broke or messed up, I'd leave it. Looks good. There will probably be a line where they were from the lack of sun and wear over the years.
Old Apr 6, 2007 | 01:41 AM
radwebster's Avatar
radwebster
chopper1 is right...the paint under the pieces will be faded differently than the paint that has seen sun for years. unless you plan on painting the truck, i'd leave them on
Old Apr 6, 2007 | 02:10 AM
spaz_22's Avatar
spaz_22
i wouldn't remove the grounds kit.....it's most likely plastic or fiberglass and weighs next to nothing...it's probably held on my 3m double sided taper and will be a son of a bitch to remove....if your thinking about removiing it becuase of weight.....you only going to save maybe 5 pounds i think
Old Apr 6, 2007 | 02:21 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: spaz_22
weight wasnt a major contributor in my idea. I just see most indys without the gfx kit and i like the way they look. then again, they are lowered too. I guess id have to see one without it and not lowered.
Old Apr 6, 2007 | 03:05 AM
spaz_22's Avatar
spaz_22
sorry got the impression you were worried about weight when you said how much does the kit way..my bad...no worries...it'll probably look alot like a blue sport dodge with white racing stripes.....oh yea quick question...looking for an exhaust for my truck...and heard yours on the let's hear your ram post....but you didn't say what you had....i'd like to knwo what exhaust setup you have...thanks a mil
