ford forum wouldnt so please help
Old Apr 9, 2007 | 11:16 PM
Ram1500Dodge's Avatar
Ram1500Dodge
Default ford forum wouldnt so please help
when at a dead stop, if i turn the wheel either way the entire truck shudders pretty badly. It only happens at idle or under 1300 rpm. any ideas on what might be causing this?
btw, its an 03 ext cab 2wd edge5speed
Thanks,
Steve
Old Apr 9, 2007 | 11:28 PM
habeba86's Avatar
habeba86
Default RE: ford forum wouldnt so please help
Do the rpms drop?
Old Apr 10, 2007 | 12:24 AM
Ram1500Dodge
well...the truck idles right around 800 maybe...and like i said, it only does it at low rpm, with it being a stick, i go to take off i hit the gas and it doesnt do it, but if i turn the wheel before i hit the gas the truck shakes until i hit the gas and bring the rpms...but no, i dont notice the rpms dropping, if it did the truck would stall i believe
Old Apr 10, 2007 | 12:26 AM
TMS Bill's Avatar
TMS Bill
Power steering pump getting weak ... I suspect.
Old Apr 10, 2007 | 01:30 AM
habeba86's Avatar
habeba86
With my ram my rpm's drop slightly if im at idle, but it doesnt shake or anythingand with my moms alero her rpm's will drop 100-200 and the car kinda shakes and is hard to turn the wheel.....Has it always done this?
Old Apr 10, 2007 | 02:28 AM
turkeyhunter1962's Avatar
turkeyhunter1962
I would have to agree with TMS Bill that it is in your power steering pump. What it sounds like to me is at low rpm when you're turning the wheel, there is more pressure in the steering box than the power steering pump. This causes the pump to actually act like a break on the engine, using the power steering belt to slow the engine down. When you are at higher RPM's the pump has more pump pressure than the steering box generates so you do not encounter the problem.
Check your power steering belt to see if it's shiny from doing any slipping when this issue occurs. It really sounds like a weak pump to me.
